jeromep's avatar
jeromep
Explorer II
Oct 06, 2020
95 Bounder 35() looking for list of bulbs
I have a recently acquired 95 Bounder 35(?). I’m trying to get all of the clearance lights and front blinker sets all working. I’m reasonably certain that I’m just dealing with burnt out bulbs, and nothing more. If this were a car, I’d just open the manual and find the light number and head to the local auto parts store and get the right bulb, but this isn’t a car and the manual package I got from the previous owner has no such listing in the manuals.
Does anyone have any quick reference material, maybe a cheat sheet or an info card, that has a listing of bulb numbers?
Thanks,
Jerome
  • RLS7201 wrote:
    Your 95 Bounder 35(?) is actually a 35U. Unique design. Opera windows, "L" couch and 60 gallon water tank in the very rear compartment. Exhibit caution when loading. Running with the water tank full (500 lbs.) will over load the 11,000 lb. rear axle.
    I suggest you use the 193 bulb for your marker/clearance lights.
    193 draws 0.33 amps and the 194 bulb draws 0.56 amps. No need to generate excess heat on all that plastic.
    Also, you interior lights are 1141 & 1142, depending on weather they are single or dual contact on the base. Do not replace those 1141 bulbs with 1156 bulbs or you will melt plastic. Same with the 1142, stay with the same part #. There are a few of us Bounder owners that have learn the hard way. GRIN
    Better yet, think LEDs
    Richard
    Richard,
    You'll have to see my post on the toilet thread, but I think mine is the 34'6" unit (based on looking up units on NADA) even through the state and my insurance say it is a 35 based on VIN. My interior isn't like the one in the video you showed but that is a cool interior for a pre-slideout RV.
    Anyway, I appreciate the feedback on the lights. Makes it a bit easier for me to just pop out and pick up what is needed and get down to work. Previous owner started to swap out the interior incandescent bulbs with LEDs that were a direct fit. Gave me a whole Ziplock bag full of incandescent bulbs he had pulled as spares. But how often do those LED direct fit bulbs really fail?
  • MrWizard wrote:
    All the markers use the same bulb,
    Just find one out of the dozen, that still has a number on it, if there is no sign of any heat damage to any of the marker lights, then the right bulb is in there
    I pulled a bulb from my 97 Bounder 36S
    Hard time reading it, but it looks like GE 193
    Looking that up on Google, 4.62watts 14v marker bulb
    Many thanks. I read a thread that suggested using the dielectric grease when putting them in. Any opinions on that?
  • Your 95 Bounder 35(?) is actually a 35U. Unique design. Opera windows, "L" couch and 60 gallon water tank in the very rear compartment. Exhibit caution when loading. Running with the water tank full (500 lbs.) will over load the 11,000 lb. rear axle.
    Richard
  • All the markers use the same bulb,
