Rich's avatar
Rich
'96 Chevy Shifter Release
I have a Rexhall Rolls Air on a '96 Chevy P30 Chassis......
and I have had trouble with a shift release relay that has been replaced once because of trouble shifting from Park to other gears.
It has started to become hard to shift again and I would like to know where the shift release override is located. I don't seem to see that information in my owner's manual. Any help on locating it would be appreciated.
  • Brian, Thanks.....Can you describe the unit with the two wires going into it?
    Thanks again.....
  • It is attatched on or near the steering column under the dash. The brake pedal is what operates it. All you need to do is take one wire off it and you are good to go. If it works right the solinoid will snap when you depress the brake pedal, this may help you locate it. By taking a wire off you no longer have the protection of having to put the brake down to shift out of park. I disabled mine a couple of years ago for the same reason. Price; "Free"
    Hope this helps, Brian
