clucerorv's avatar
clucerorv
96 Georgie Boy Water Tank
Does anyone know how many gallons the fresh water tank holds on a 1996 Georgie Boy Cruisemaster? Our 1st time using fully self contained and barely got 3 very quick rinse and off showers. What are we missing?
  • Bruce Brown wrote:
    Also check the overflow. Many times if you fill the tank 100% it can hit the overflow, which will create a syphon and you'll lose a bunch of that 82 gallons.
    This is definitely something to look into. When we first got our GBM (I was a complete RV newby), I filled the freshwater tank until water came out the overflow and stopped. Usually right before pulling out of the driveway.
    Most of our first year trips were within 2-3 hours of travel so we didn't even usually stop along the way. On our first longer trip, I pulled into a rest area about 80 miles from home. As I exited the RV, a fellow RV'er told me that we're leaking freshwater! I checked, and sure enough, he was right. The dreaded "siphon problem".
    My solution was to get a couple of shark bite shut-off valves and install them on the ends of the two over-flow pipes. (My rig has 2: one on each side directly behind the rear wheels.) Now when I fill up the water tank, when water flows out the drains, I close those valves. The next day, after some water usage, I'll open the valves and usually the situation is resolved. If water is still leaking, I'll close the valve and check again after we use more water.
    With a crew of 2 adults, 4 children and a dog or two, I wanted to maximum our freshwater carrying ability.
    So, definitely look into that possibility on your rig. It might even be fine when you fill the tank on a level, but upon travelling up/down hills, the water might slosh enough to get a siphon started.
    Good Luck,
    ~Rick
  • Also check the overflow. Many times if you fill the tank 100% it can hit the overflow, which will create a syphon and you'll lose a bunch of that 82 gallons.
    In every MH we've owned (5 of them now) I've put a T in the overflow line and extended a vent that effectively stops the syphoning from happening.
  • I found specs for 1996. It shows 82 gallons fresh and 52 gallons for each holding tank. GAS chassis. Doug
  • Dutch_12078 wrote:
    gbopp wrote:
    It looks like it holds 82 Gallons.
    A lot of specs could have changed between 1996 and 2008...
    Good point, I didn't see the specs were for a 2008.
    I googled a 1996 and that is what came up.
    Thanks.
  • Hi,
    Do you have a model number for that Cruise Master? We have a 2005 (on a 2004 chassis) and the freshwater capacity is 75 gallons. From the GBM brochure I have for 2004, they used two fresh water tank sizes: 62 gallons or 75 gallons, with the 75 gallon size being used more frequently.
    I believe in 1996, the Cruise Master was available with a diesel chassis? Is yours a diesel or gas? When we bought ours, the Cruise Master line was only built on the Ford or WorkHorse gas chassis.
    Unless it's one of the shorter (25'-ish feet long) models, I think it's safe to say it would have at least 60 gallons of freshwater.
    If you can tell us any more info, I'll see what I can dig up.
    ~Rick
    If you can access the tank, measure the height, width, and depth to calculate the cubic footage of the tank. A cubic foot of water is 7.48 gallons. Realistically, there's always a small air space even when the tank is "full", but the measurements will get it pretty close.
