kdk's avatar
kdk
96 Windsor chassis wiring diagram
Helping out a friend stranded at a campground and am in need of a chassis wiring diagram for a 96 Momaco Windsor with an 8.3 Cummins engine. There is a start solenoid with 2 large and 2 small terminals mounted on the passenger side of the engine compartment that is not energizing. Jumper-ed across the 2 large terminals sending 12 volts to the engine starter solenoid and the engine started. Don't seem to have any power from the ignition switch to this solenoid to energize it. Does any body have one or know where I can get a diagram of this circuit. I'll try Monaco tech support later today after they open, just trying here in case they can't help. Thanks in advance.
Blessings; Keith
  • Unfortunately my RV is at the shop so I can't scan in the schematic. Try going to the Monacoers group on Yahoo. Since Monaco isn't in business any longer you might find somone there who can help.
  • If that Windsor has a magazine rack in the center of the "dash", Pull it out and there may be a schematic on the back of it. Also there may be another under the bed platform if it lifts up to get into the engine compartment.
  • Suspect this is a Monaco, not Holiday Rambler Windsor.
    Do other items like the dash HVAC fan that only work with the key ON work? If not, look at the IGNITION SOLENOID which gets its signal from the ignition switch. Likely in the front of the coach.
