wbrowningExplorerApr 25, 201699 Chieftain 5.9 Cummins wont stay runingEngine was running with reduced power so I changed filters it seemed to not be picking up fuel so I changed lift pump same thing if I get system primed it will run for a few minutes then die if you p...Show More
wbrowningExplorerApr 25, 2016I hope some body can come up with a diagram of the fuel system I do not believe it has a priming pump.
Related ContentCummins Hit with 1.7Billion for Emissions Defeat Devices2025 Cummins6.7L Cummins VS 6.7L Cummins HORam Cummins/Aisin Failures34 ft 89 winnebago chieftain
