snickster's avatar
snickster
99 Monico Windsor and Silverleaf VMSPC
I have a new to me 99 Monaco Windsor that I would like to connect a Silverleaf VMSPC that I have been using on a 98 HR Endeavor.
The Windsor has the Cummins 8.3 L Engine with the Allison engine and the
Endeavor has the Cummins 5.9L ISB.
Is the VMSPC able to connect and work with the Windsor. I don't see any connector that will match the VMSPC Hardware connector.
Heading for the Rockies soon , and I would sure like to be able to have
all the data available that the VMSPC provides while climbing those grades. ( Especially on an unfamiliar coach !)
Thanks
  • I second calling Siverleaf, they are great to work with.
  • You could call SilverLeaf Electronics at 888-741-0259, or you could hook it up and go to the Advanced menu and under Engine Type select the correct engine. Not all engines support all potential gauge items. If a particular gauge always reads zero, your engine simply does not support that feature. Good Luck. Gary Maybe I'm not addressing your hardware question, but it seems to me if you had it hooked up to a Cummins engine before it should take the same hardware!
