Twomed
Sep 09, 2018Explorer
One that will pump up to 135# plus.
Block the coach up with cribbing before you crawl under to do the drive shaft, do not depend on airbags or jacks.
Mark the position of the shaft in the axle end yoke, unbolt the axle end and chain/strap up securely. Remove bearing caps and store them so they don't fall off. Purge well with fresh grease when you re-assemble.
38,771 PostsLatest Activity: Apr 15, 2026
