Tkotis5
Sep 05, 2015Explorer
A check list
We are brand new to this does anybody have a check list they do before they leave the house with their rv and when they leave a campground? Any help would be great!!
toedtoes wrote:rjxj wrote:Coach-man wrote:rjxj wrote:Coach-man wrote:rjxj wrote:
Not in order
Clean off slide
Hitch latched
Breakaway cable
7 way cord not pinched
Awning latched and locked
Steps in
Handle in
Stabilizers up
Chocks removed
Landing gear high enough
Nothing to fall on stove knobs
Landing gear support knobs tight
Sewer hose tray latched
All compartments locked
Door locked
Windows closed
Antenna down
Bikes locked and secured
Vents closed
Cupboard doors barred
TV off wall mount
Wedges under slide
Tire pressure
Items off counters
Tail lights working
Water pump off
Wheel leveling boards picked up
Slide closed properly
Test tug hitch
Test brakes
Landing gear? Test tug hitch? The op is in a class C, you may be confusing him? Also, why take the TV off the wall mount?? Good start, one thing I would add is check antenna to be sure it is down.
I don't see your list.
Tooconfused by landing gear and hitch! And since other than that your list was pretty complete so why list the same things?
So you basically had nothing worthwhile to add. No list, no additional good info, just nit pick others. Thanks for your time we really appreciate it.
Sheesh. He was simply pointing out that some of the items on your list were dependent upon the type of RV and that could confuse the OP since he has a different type.
Not in order
Clean off slide
Hitch latched
Breakaway cable
Steps in
Handle in
Stabilizers up
Chocks removed
Door locked
Windows closed
Antenna down
Vents closed
TV off wall mount
Wedges under slide
Tire pressure
Items off counters
Tail lights working
Water pump off
Test tug hitch
Test brakes
