-Gramps-'s avatar
-Gramps-
A Few More Tips and Hints
1. I leave a baseball cap on the dash whenever I am driving the coach. I don’t wear it all the time but it sure comes in handy when the sun is low and shines thru the gap in our double automatic windshield shades.
2. While we are on the subject of windshields. I replaced my stock Monaco wiper arms with ones with standard sized J-Hooks. I purchased them from Diesel Equipment Corp in Greensboro NC. Now I can use any length frameless replacement blade, easily purchased from an auto parts store or Wal-Mart.
3. Rescue Tape works as advertised. I carry three rolls of it, Red, Orange and Clear. It can fix a hose, a broken patio umbrella and there are lots of useful reasons to have a roll in a drawer.
Capillary action (sometimes capillarity, capillary motion, or wicking) is the ability of a liquid to flow in narrow spaces without the assistance of, and in opposition to, external forces like gravity.
Do you read that? Water can go against gravity, flow UP, if the conditions are there. So here is hint number four…it’s a bit long but I suggest you read it.
4. If you have a Monaco or Holiday Rambler coach with the rubber black gutters at the bottom of the side of each of your slideouts then you need to take a close look at the bottom of the floor of each slideout, especially the main one. That piece of rubber was installed to catch the water running down the side and not let it run under the slideout where it gets wicked up by the plywood floor. There is an exposed wooden edge underneath the main slideout that is well, too exposed. The rubber gutter helps to prevent a leak problem but it doesn’t quite do the trick. The gutter funnels a lot of water to the front bottom corner of the slideout causing the floor to delaminate and then it starts to soak up water and it swells and the cycle just gets worse until one day mushrooms are growing out the bottom of your slideout. Not good. I discovered this was happening to my coach. I had a lot of rotten wood which I blew out with an air compressor and then filled the void with spray in stop gap foam in a can. Then I glued a piece of rubber sweep over the edge of the slideout so the water could not defy gravity and run underneath any longer.
If you discover you have this problem you can limit the exposed edge of the floor by running a line of deck screws through the bottom of the floor until they are flush! Don leave any exposed screw head or it will get caught when the slide goes in and cause a lot of grief.
6. Learn where your ice maker shut of valve is located. You don’t want to be caught by surprise and have to turn off the campground water to your coach because you can’t figure out how to turn off the water to the icemaker…not to mention the damage a leak can do to your fridge electronics.
7. After you learn where your shutoff valve is, I suggest you replace the standard plastic tubing water supply line to your ice maker with a reinforced icemaker hose. Why risk a leak from a broken water line caused by the fact it moves when the coach moves? This part is available at Lowe’s for around 15 bucks depending on the length. I bought a six foot one. It took about twenty minutes to connect it.
8. I have a rechargeable flashlight/night light plugged into a bathroom socket. Its in the middle of the coach and comes in handy during an emergency, like the dog needs to go out in the middle of the night and I don’t want to turn on the lights in the coach.
9. I carry a CharGriller table top grill. It is a small kettle grill with cast iron grates. Best portable charcoal grill you can get. It fits in the basement but large enough to cook a mean six pound beer can chicken. This grill is available on line or at Lowe’s for around sixty nine dollars.
10. Do you have a dog that likes to spend a lot of time on the dash? Diane and I made a custom fit dash mat. We purchased comfort rugs…those things that usually go in a kitchen or laundry room and are designed to be easy on the feet. They are made out of the same thing that mouse pads are made form…urethane rubber. We trimmed the rugs to fit around the instrument panel and it looks really good on the dash. Maybe I will post a picture later.
Well, that is all the hints I can think of at the moment. I suspect that some more will pop into my brain and I will add to this list if that happens.
Gramps.
  • Community Alumni's avatar
    Community Alumni
    So, I'm not the only one who does this! :C
    Community Alumni
    Executive wrote:
    I'm curious about the ice maker line replacement. It's my understanding the fridge has to be pulled out to access it. Or, are you referring to a residential fridge.???..if you're talking about a Norcold, I'd like more info. I want to replace mine.....thanks...Dennis
    I'm interested in it too. I replaced the small tubing from the shut-off to the solenoid because it became brittle and broke apart. I imagine the tubing behind the fridge might be hardening. It's thicker but is exposed to the heat behind the fridge.
  • That large, white motorhome dashboard is an eye-killer when driving with the sun ahead of you, and you can sure feel the reflected heat. At night, it sometimes causes annoying, even hazardous, bright reflections on the inside of the windshield.
    I suppose, you could paint it black, which would cure the reflections, but then the dashboard would turn into a blast furnace on sunny days. The simplest cure is a black, or very dark-colored, dashboard mat -- it absorbs both the light and the heat, without re-radiating it.
    You can easily make one from a dark carpet remnant, or buy an eight-foot length of hallway carpet runner at Home Depot, then trim to fit. If you haven't done something like this before, especially if your dash is not a flat slab, make a template out of heavy wrapping paper to follow the contours, then cut out the carpet. Stick-on Velcro tape, or a few well-placed stainless-steel snaps, will keep it from sliding around.
  • I'm curious about the ice maker line replacement. It's my understanding the fridge has to be pulled out to access it. Or, are you referring to a residential fridge.???..if you're talking about a Norcold, I'd like more info. I want to replace mine.....thanks...Dennis
  • Thanks Gramps. Nice ideas. Pictures would be greatly appreciated, especially before and after on the wiper arms and slide gutters.
