Spizzer
Aug 04, 2014Explorer
Executive wrote:
Mine is tied to the door switch. If the door is OPEN the steps will stay out, but if the door is CLOSED and I turn on the ignition switch they will retract. This is regardless of the position of the lock open switch.....Assuming yours was the same, it sounds like someone wired around this for whatever reason.....Dennis
Dennis,
THat is what is puzzling....it was working as it should, but then stopped retracting when the ignition was turned on.
Something has failed.
jeff
