Spizzer
Aug 06, 2014Explorer
gsf35099 wrote:
Jeff,
Is your door closed and the steps stay out with the ignition on?
That is correct. It used to come in when the ignition was turned on, but something happened and it stopped doing that. In trouble shooting, I found that that unknown green wire was causing the voltage on the "ignition on" green wire to drop from 12 volts to 2 volts. I removed line and now it works perfectly. HOwever, I don't know what the purpose of that green wire is.
Thanks,
jeff
