Spizzer
Aug 07, 2014Explorer
dougrainer wrote:
Kwikee will NOT have that green wire shown. The green wire and the resistor or diode is installed by the OEM maker. Doug
Doug, you are 100% correct! The step manufacturer said it was a diode in there, but to contact Winnebago to find out why. I called Winnebago and they said it was a diode to remove any possibility of step operations feeding 12 volts back into the ignition circuit when the ignition is off.
I get the diode, but still don't really understand the ground wire and its function. Need to take it apart and build a new one.
Thanks everybody for all the thoughts, ideas, and suggestions!
Jeff
