- BULLETLS1ExplorerI did change the distributor, there was a sale in summit racing, 50bucks a billet one, high perf coil, nice 9mm wires ceramic spark boots, 1number leaner jets (yes, still has a carb), the injector in the "least injection hole", carb spacer (I think it was a waste of money), and definetelly north of 10mpg! Keeping @50mph
30footer. - joloooteExplorerNice job. Almost exactly what I did on my P30 years ago. U really need a tach in older P30s. When you see the needle start getting irradic its time to replace the 2 modules inside the distributor.
- Doc_EagleExplorerLast fill up 9.5 mpg, put air in tires, may help some more. Tach and vacuum guages working great. Keeping tach between 1700-2000 rpm, seems to be working out. Get pasted by alot of vehicles but don't care, they pay for my gas I'll go faster, not in hurry to get anywhere. Keep you'll posted on next fill up.
- Deano56Explorer IIwow 8 mpg, I think my carbed 1990 P 30 34' MH gets around 6 mpg but not sure
- turbojimmyExplorerMine's an '84, but my dash looks just like that. Neat idea! My brake light doesn't seem to work anyway....
- Doc_EagleExplorerWell keeping speed at 60 mph with cruise control and first true reading was 9.3 mpg. Got a couple things more to try but pretty happy right now.
- GjacExplorer III
Doc Eagle wrote:
I think that vintage 454 develops max torque at 1800 rpms. I have a 1995 454 tbi on a 1996 chassis that is 33 ft and weights about 15,000lbs (UW is 13,000 lbs). I have aved 8.7 mpg over 60k miles. I think installing the vacuum gauge will help mpgs more than watching the rpm. When I installed my VG I put a black pointer on mine at 15 ins and try to keep it above that line for best fuel economy. Also I know at what point the trans will downshift so I can increase the vacuum by letting off the gas and keep it in 4th gear. If I travel between 50-55 mph I can get between 9-10 mpg with no generator use using the VG as described and secondary roads. Below 45 mph and a slight hill trans will downshift.
Well actually I would really be happy with 9-10 mpg. My guys at work call our MH "Cat One" due to my wife's cat rescue activities. Of course it is really one of the only cat free zones in the yard. Has anyone else heard that 1700 rpm the best range for economy on the TBI 454? - Doc_EagleExplorerOk, finally got the tach installed on the MH. Since I choose a small tach it fit between the heater control & speedometer. Also installed a small vacuum gauge to the right of heater control. And they both work... hurray!
- Doc_EagleExplorerWell actually I would really be happy with 9-10 mpg. My guys at work call our MH "Cat One" due to my wife's cat rescue activities. Of course it is really one of the only cat free zones in the yard. Has anyone else heard that 1700 rpm the best range for economy on the TBI 454?
- DaveinetExplorerShe may have gotten 12 a few times, with the way things work. Notice his coach is only 22 feet long, so it is very, very light weight. My parents 27 foot Midas got 8 to 9 mpg, until the fuel pump went out. They replaced it with an electronic fuel pump, and never once got below 10 after that. Most of the time is was over 11 mpg. The difficulty you have is those throttle body injection versions from that time period did not do too well, especially in colder weather. The timing curve is not optimal, which doesn't help much. You may be able to chip it, for a better timing curve and get a little more out of it.
38,761 PostsLatest Activity: Nov 18, 2025
