i2forglory's avatar
i2forglory
ABS BRAKING SYSTEM
I own a 2006 Damon motor home. The abs system stopped working. I had an rv mechanic work on them, he swapped the sensors around and also tried a diagnostic unit to no avail. Do you guys have any insite!!
The glory man
  • When my ABS light would not go off. I thought I had really big problems. I followed every ABS wire from brake area to under hood. Found loose connection right above diff cover. Must of got knocked loose with some road debris? Plugged back in and light went off.
  • Its a Ford chassis isn't it??? Take it to a Ford truck dealer. They would know all about it as it is their system.
