dtrink's avatar
dtrink
ABS data connector
I have a 2003 Gulfstream Sun Voyager on a Workhorse chassis. The ABS light came on and I stopped at a repair facility to have the code checked, but we can't find the plug to hook the scanner to. Does anybody know where it would be located? Thanks.
  • On our 2005 Gulfstream Class A on the Ford chassis, Mechanics had a very difficult time trying to find the connector. Finally fount it up above the steering column.
  • You can use a scanner, or you can just use an ohmmeter. About two feet from each ABS sensor on each wheel, you will find an electrical connection. A good sensor will read about 1200 ohms. A bad sensor can either be shorted(zero ohms) or open (infinity). The sensors are very easy to change, without any tools, and they cost about $90 each.
    Oops, sorry! They have gone down in price since I last bought them. They are now about $77. ABS sensor
  • on our 20004 workhorse chassis it is just to the left of the steering column but hiding behind a shield around the column as I remember.
