Tom_BarbExplorer IISep 10, 2021ABS light.What is required to reset the ASB light? 2000 Newmar - Cummins 8.3 - Spartan chassis. Applying the brake 3 times with the key on doesn't work. Disconnecting the chassis battery, doesn't work. U...Show More
sch911ExplorerSep 10, 2021The system has an active fault. Scan the vehicle. Find the fault. Correct it. Clear codes. Lights out.
Related ContentTowing lights issueABS LightABS lightAdvance Trac Light On / ABS and Crusie DisabledReplacement Lights for TT
