What is required to reset the ASB light? 2000 Newmar - Cummins 8.3 - Spartan chassis. Applying the brake 3 times with the key on doesn't work. Disconnecting the chassis battery, doesn't work. U...
on most automotive vehicle abs lights reset on their own when you turn the key the abs module reads resistance on all sensors and soliniods if it finds one it doesnt like the light stays on if the problem is corrected when you drive down the road light will go off look at all the wheel speed sensors and see if you have a broken wire
