Tis a little information if you have a problem with your ABS light not going off. The code did not pin point this problem, This was found with a Monaco tech helping the tech on the MH, all sensors wor...
What made my hot they had 5 Tech in that shop, I bet between the five if you would add there hrs together that would not total 21/2 hrs each working time.
