rgatijnet1 wrote:
The sensors just pull right out. Might be a little tight but they will slide right out. The electrical connection is about 2' from the sensor. Use your meter and you can read the resistance on your sensors. The one that reads different is bad. A good sensor will read about 1000 ohms.
If they all read OK then just clean them and reinsert them on each wheel. Be sure to push them all of the way in until they will not go any further.
Use compressed air to blow the brake dust and road grime out of the hole the sensor will be installed in.
