devildog1971's avatar
devildog1971
Warning Light on 2002 Monaco Diplomat
I checked the manual and it states to stop and check all fluids. the coolant is ok , the oil level is ok, the oil pressure is at 60 at idle the coolant is 190 degrees. the transmission shifts alright I need to locate the dip stick for the transmission. I think it is a malfunctioning sensor. I drove it home 600 miles sometimes after a stop it would come on sometimes it did not light up nothing seems out of the ordinary? except the light is on the air pressure stays around 120 pounds and does not leak down when the engine is off HELP
