winniman
Jun 10, 2019Explorer II
What transmission do you have. If you have the 3000 or better, you can check the transmission fluid with the shift selector pad. The manual says it is more accurate than the dipstick. The transmission has to be warmed up to do it. Just hold the up and down buttons at the same time. It will give a code indicating the level. The exact instructions will be in the allison manual that came with the rv. If you have the 2500 series or less, this feature is not available.
