GlennLever
Sep 21, 2014Explorer
edm3rd wrote:
Suggest contacting RV manufacturer. On some, fan runs constantly when a/c is turned on, others are temperature controlled by a thermostat and the fan is only turned on as needed.
Does it cool adequately when driven at highway speed (ie when there is enough air flow that the fan isn't needed)?
I have sent an e-mail to both Gillig the chassis manufacturer and Fleetwood, no response from either.
A/C dash vents have cool air coming out, but not what it should be.
There are no sensors on the condenser coil to signal the fan to come on and off.
Wire for the fan runs directly away across the frame, to the electronics compartment.
38,782 PostsLatest Activity: Sep 10, 2026
