Gjac
Sep 21, 2014Explorer III
Glenn I don't know if this will help or not but I have a P-30 chassis with an Evans tempcon system and there are two things that control the fan. One is a temp sensor in one of the heads and when it reaches a set temperature the fan s comes on. The other is a small pressure switch with three leads going to the switch sometimes referred to as a trinary switch. One of the leads comes from the A/C. When mine was leaking it would not blow cold air. I changed the switch and recharged and all was well again.
38,782 PostsLatest Activity: Sep 10, 2026
