GlennLever's avatar
GlennLever
A/C Cooling Fan / Radiator / Cooling
This topic kind of ties into one already started 8.3 Overheating but has to do with the A/C condenser.
I have discovered that the electric fan on the A/C condenser does not come on when the dash A/C is turned on. In a car this fan would come on as soon as the a/c is turned on, should that also happen in this motor home (1997 America Dream).
Before I start checking would like to know if that is how it should work.
If so the first thing I would check is, is there power at the plug, then I would hot wire the fan to make sure it is working, if it is the solenoid I would love it if someone could take a picture and describe it's location.
Should the fan be lowing into the condenser coil or sucking air out (not fighting the Motor Home fan)
Just a note, this may be another example of incompetent RV Service center repairs. At the beginning of the season I took it to Caledoina RV because the A/C was not blowing cold. They charged the system and pronounced all was well. On the next trip it did not work until we hit a big bump, and then it did work. It has worked off and on again ever since. It was taken back, but they stated all was well.
  • works off and on,I,d check the wiring to that fan, and in my opinion the fan should come on when you turn the air on, ac working hints a loose wire.
