supercubExplorerApr 21, 2015AC foam filter?I need to change the foam filter for the AC units. The inlet filter is foam and is mounted in the ceiling. Where do I get replacement filters/foam. Thanks Brian
wildtoadExplorer IIApr 21, 2015You can also find foam filter material at lowes or Home Depot and cut to fit.
Related ContentCleaning your AC FilterFoam air filter disintegrating, clogging carb, alternatives?AC filterCleaning AC filterAC filter material
