brodon's avatar
brodon
A/C not cooling
Have coleman Floor A/c HEAT PUMP SYSTEM. HOT AIR BENEATH THE UNIT. SOME WATER DRAINING OUT OF PAN. SEEMS LIKE ONLY ONE COMPRESSOR IS ON. 30/50 SWITCH IN ON 50. COOLING IN MORNING IS GOOD. ANG SUGGESTIONS?
1 Reply
  • Sounds like the unit is freezing up..turn it off and see if ice drips off the evaporator....the fact that it is good in the morning and eventually stops blowing cool air sure points to icing up.
