MamaGoose wrote:
Well, I'm beyond frustrated. DH is really busy with work stuff, I was hoping this would be simple.
We replaced the batteries. The EMS control panel shows power to all appliances. All lights are on the right side. However, the center where the available amps is supposed to show is blank. Nothing requiring AC works. The control panel that shows the battery state doesn't show AC going in. The incoming breaker amp shows 20. I can't change it to 20 on the EMS panel, the light is on beside the 50. The service select button does nothing.
There is power to the outlet that the Motorhome is plugged into. When I unplug it the EMS control panel goes dark. I tried that thinking the adapter between the huge Motorhome cord and our power cord may not be working.
Mama Goose. We have the identical coach to yours. Are you OK with receiving a phone call. We are from Canada but are currently in Zion Park in Utah. If you are OK with the call send me a Personal Message and Ill give you a call at your convenience....and assuming we are not hiking.
