SnomasExplorerAug 09, 2017A/C problemMy 2 roof top A/C units were replaced in November 2014 w/ new Dometic 15K units and also installed was an upgraded new thermostat. The rear unit will not come on. I checked the thermostat for inside t...Show More
newman_fulltimeExplorer IIAug 09, 2017if the unit cones on and runs correctly when the therm is put on 50 it tells me the therm is bad and nolonger calibrated correctly
Related ContentTruck Camper A/C instalationA/C problemA/C ProblemsA/C problemAtwood water heater problem
