balfre1946's avatar
balfre1946
AC unit intake drips water
We are in a 2010 Fiesta Fleetwood 36B class A with two Coleman A/C units, and the back one has often caused us problems in this hot South Carolina climate. They are working ok now but water is strongly dripping from the back intake unit, never done that before. Any thoughts on why? You guys are the RV geniuses!
  • On Coleman AC units, if the top unit mount bolts are over tightened, the 2 drain holes will be blocked off by the roof and the water will drain inside. If the gasket does NOT have at least 5/8 inch thickness, replace the gasket, it has collapsed from overtightening. Doug
