MrWizard wrote:
want to know what volatge the A/C unit is seeing
remove the covers from the circuit breaker panel
use a multimeter set on AC volts 200vac or higher (usually something like 600vac on the meter )
read from the neutral bar (the white wires buss) to the A/C breaker
probably safer if you get somebody else to do it
Thanks for the info! So there is no set info on whether the AC’s are getting the voltage coming into the rig or getting the voltage after the line drop on the internal VM?
I see you have near the same rig.. my rig is a 1997 F53 chassis too.. how do you run your AC’s together on 30 amps? Thanks!
