yes i'm in SoCal
i'm sure the generator is running near max
but at these temps the A/Cs are hot and pulling full power
the Onan gets hot and gets to point where it is difficult for it to do compressor restarts
put the A/C's on auto, select a low enough temp on the stat, that the A/C comes on and stays on, does not cycle the compressors
makes it a bit cool in the morning, but that helps combat the heat penetration
did 20hrs on batteries for the 12v systems (led lights, water pump, fridge and thermostat controls) aka parasitic loads
did battery charging this morning 3hrs this morning before turning off converter circuit breaker
ran the generator and one A/C all night last night, right now 105 here
