Terryallan wrote:
I;m thinkin, with 2 13500s on top, You should be able to hang meat in there. Are they working properly?
If they are working properly, are are still not enough. You can trade them out for 2, 15000 btu roof ACs, and you won't have one hangng out of your window.
Another thought, is install ceiling fans in the coach. May be all you need.
If you ever go to Texas and the temps hit 100 or more those 2 13000 ac are not cold enough , when I can buy 1 window ac for under 300 which is a lot better than spending thousands . As far as hanging out the window I could care less what it looks like as long as it cools down some.
