- wolfe10ExplorerHave you identified if this leak is on the pressure side (from faucet) or drain side?
Easy to tell. With faucet off, pour a bucket of water in the sink to see if that leaks. - CA_TravelerExplorer IIINo leak when off suggests downstream valve leak that you haven't identified or drain leak.
No clue about your cabinets but side/floor panes can often be removed and if not start with small holes for visibility. You can always make a thin plywood cover for a finished look.
38,782 PostsLatest Activity: Sep 10, 2026
