Gazelle05's avatar
Gazelle05
Add 110 receptical
Want to add another receptical to coach. Can anyone tell me are recepticals on a daisy chain? If the outlet is tied into the inverter it has two lines going in. Is one feeding the next outlet? If so how can I connect another outlet without breaking the chain?
Thanks
  • Yes, simply daisy chained. Doesn't need to be overly complicated. Simply use Romex and extend per the usual NEC methods.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok. outlets are indeed dasiy chained. in most RV's. However there are ways to add additional outlets depending on the intended use.
    Low power if you can run a cable (romex) back to the distro point. You can simple connect in there (IF the inverter has breakers it is the distro point, IN my case I have a "Sub Panel".
    High power. skip the inverter and run 12ga Romex back to the main breaker box (how I did did it (yes I did it two times).
    I use electric space heaters so the added outlets are 15/20 amp (Have a "T" shaped neutral) and one to a circuit breaker. NO aroma of overheated wire/connection since I started using those for the heaters.
