debandi's avatar
debandi
add ATF for power gear levelers
I need to add ATF to my Power Gear levelers but can't find where where Fleetwood put the container. I believe I need to add ATF to shut off he 'jacks down' alarm.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    This is one of the easier jobs. The "Container" (Tank, reservoir) is about 1/10th inch from the pump.
    SO here is how you find it.. Have your significant other operatre the jacks while you go out side and listen for the pump.. Follow your ears and there it is
    TO FILL
    Raise jacks, FULLY, then remove the screw, fill till fluid comes out teh screw hole (THE very fne manual will tell you which screw)
  • That should be on a Spartan Chassis, and on our 03 Tradition, most all fluids and filters were in the drivers rear of the coach. Check there first, or where ever all your filters are place on that year coach. It will be a tank approx 7-8" in diameter and maybe 16" tall, I think. Listen for the sound of the pump while someone presses the button in side, as the previous poster suggested. Best of luck. Happy trails, Bert
  • listen for the pump motor while jacks are extending. If a vertical tank with pump mounted on top retract jacks and fill to top of fill plug.
