richclover
Jul 28, 2020Explorer
Gdlow wrote:gbopp wrote:
I didn't realize some RV's had suction ports to draw in water.
Don't you have a regular gravity fill where you use a hose to fill the FW tank? That would work with a drill powered pump.
Nope...No gravity fill.
No gravity fill on my new 5’er either. With 40 gallons useable I needed a way to add more.
I cut an older 25-ft hose in half, added fittings from Ace Hardware, found a 12-v pump on Amazon and added a length of wiring and a plug that fits the solar panel plug. Hooked up to the city water input, with valves set correctly, it’ll transfer a 6-gl jug to the tank in a couple of minutes.
I’m wondering where you’re losing your water?
38,783 PostsLatest Activity: Sep 22, 2026
