Gdlow's avatar
Gdlow
Add water to class A while boon docking
For some reason the onboard pump works to transport water inside the coach, but won't when trying to use the suction port to fill the water tank from a non pressurized system. Anything I could check to troubleshoot? I maybe doing it wrong...been known to happen:o
Scondly, If I use a portable pump attached to a drill will this fill the tank if set on tank fill on the service panel?
Inquiring mind needs to know...thanks
  • You might need to go to the manual. While i dont have a rv, my TT dosent have a gravity fill. You need to set the knobs in a certian way on the pump to get the suction to work. On mine it's the same as when i wimterize it. Good luck.
  • I didn't realize some RV's had suction ports to draw in water.
    Don't you have a regular gravity fill where you use a hose to fill the FW tank? That would work with a drill powered pump.
