JCat's avatar
JCat
Explorer III
May 02, 2015
Addded a 3rd AC unit -IT IS GREAT !
I just completed the add of a 3rd AC unit
I hired an AC guy to do this upgrade as this was too much for me to do by myself.
Removed the kitchen ceiling vent, placed new AC unit in that opening, fit perfect.
Ran the thermostat wires across the roof to the bedroom AC and hooked them in there.
I control all 3 units at thermostat.
The 110 v had to be run across the roof, and is connected to a 20 amp breaker box, that then plugs into the 30 amp service at the pedestal. The 110v cable plugs into the ac unit and is removed when traveling.
I am in Palm springs currently and it was 102 degrees here yesterday.
With the 3rd ac unit on the inside temp was 71 degrees and cold.
I had wanted to hook into the RV's electrical system but this was not possible.
I called Thor and talked to a tech who helped build the Mandalays.
There is no circuit currently wired for a 20amp draw that is not already in use.
So I had to wire the unit outside of the rv's electrical system.
Only drawback is I have to go on the roof to plug and unplug the unit when traveling.
JCAT
  • Sounds like a pretty ingenious way to get a third AC installed. Plugging in the extra cord at the 30 amp post will work great since you will only have to do it during summer months.
  • Good job..Do some thinking and figure a way to not have to go on the roof to disconnect.That will get old in a hurry and increases the risk of a fall...
