michelb
Jul 09, 2013Explorer
As long as your power requirements are not very big, you could easily simply re-wire the wires in the breaker panel to move from non-inverted side to inverted side. Ideally, if you don't use the TV, swap the wires from the TV plug to the plug you want to use. If you do want the TV on the inverter, it's probably not a big deal to have both on the same breaker as long as you aren't running heavy electrical draw.
38,766 PostsLatest Activity: Jan 10, 2026
