Pauljdav
Jul 09, 2013Explorer
You can add wire from the closest inverter outlet to the location of the CPAP and add a new outlet to that location.
When I added my inverter I put an outlet in the bedroom and one by the entertainment center. These are the only areas I will need inverter electricity and it is easy. I had to gain access to the underbelly by removing some screws and there is a lot of room to work down there.
It is also easy to run the wire to almost any location because there is already wires and water lines going from the under belly to interior locations.
Paul
Paul
38,766 PostsLatest Activity: Jan 10, 2026
