bigcritter
Jul 10, 2013Explorer
michelb wrote:
As long as your power requirements are not very big, you could easily simply re-wire the wires in the breaker panel to move from non-inverted side to inverted side. Ideally, if you don't use the TV, swap the wires from the TV plug to the plug you want to use. If you do want the TV on the inverter, it's probably not a big deal to have both on the same breaker as long as you aren't running heavy electrical draw.
That sounds like a really good idea. The power requirements on the machines are pretty low, so long as we're not using the humidifier, which we rarely use, 'kinda like the TV in the bedroom. We rarely watch the TV in the bedroom, and if we decided to, we could just run an extension cord over to it from the main outlet. Thanks!
38,766 PostsLatest Activity: Jan 10, 2026
