Sam_Spade
Jul 12, 2016Explorer
And not that it makes much difference as far as the answers go but this thread is in the CLASS C forum but you seem to have a 5th wheel.
First, have your present battery tested.
Then have the converter/ charger tested.
If either of those fail, fixing that might solve the problem.
But converting the lighting to LED is still a good idea.
If it ends up that you do need extra battery capacity, two 6 volts in series is a little better than a second 12 in parallel.
38,774 PostsLatest Activity: Apr 26, 2026
