Dakzuki
Jul 12, 2016Explorer II
1) Convert to 6 volt true deep cycle (like GC) batteries (virtually all 12V wet cell batteries are not true deep cycle).
2) Get a multi stage converter. Most RVs are still coming with single stage converters that charge slowly and are not good for leaving your RV plugged in for extended periods. A multi stage unit like what Progressive Dynamics offers will charge faster and can be left hooked up indefinitely.
3) Convert to LED lighting.
4) Add solar. This will keep the batteries charging during the day, all day (if you are in the open).
5) One can also go a little nuts and install AGM batteries. They are sealed, charge faster than wet batteries (if your charger can supply the current), and are better at deep discharges. Down side is they are expensive.....like 3X. I did it anyway.
38,774 PostsLatest Activity: Apr 26, 2026
