- Up to four in parallel is fine.
- azrvingExplorerIn series? It will give you 24 volts and the lights will be brighter than you have ever seen them before, but just for a split second.
If you want to run them in parallel the voltage will stay the same but the amperage will double so your run time will double.
38,761 PostsLatest Activity: Nov 28, 2025
