I just added 4ea. Noctura NF-12 fans to the upper exhaust vent. After doing way more research than I ever thought could be done on fans, these were chosen because they are EXTREMELY quiet for their CFM airflow, they're IP65 environmentally rated and can live in temps of 250 degrees plus. All 4 at full speed can barely be heard with your ear in the outside vent, and not at all inside, all while easily holding a piece of paper flush to the vent from suction. I run them on a PWM speed control at about 30% and when in LaQuinta a few weeks ago ran them on full at 95+ with the sun on the fridge side and was struggling to keep is above 28 degrees on temp set 4. The plan is to tie the PWM controller and fans to an ARP and let it run the show as needed.
If I did it again I would probably use only two fans but overkill is always good with these fridges.
