RacerX10
Sep 16, 2015Explorer
Adding Step Switch / Need Wiring Diagram for Fleetwood
My 2013 Fleetwood Jamboree 25k has a kwikee fold out step, but it (oddly) doesn't appear to have a disable switch, like I've seen in pretty much every other rig. The switch is what you would turn the step off with when you are parked somewhere so it isn't going in and out every time you exit / enter the coach, you'd just put the step out then turn the switch off.
Anyhooo .. it looks like the white wire on the 4 pin harness is where the switch goes, but Fleetwood doesn't appear to have carried the 12v down to the header that I need for that switch I'm going to install.
TL,DR does anybody know if Fleetwood gives out wiring diagrams for these things ? The set of books I have from Fleetwood is just generic RV info, nothing specific to this model.
