Harvard
Feb 24, 2015Explorer
Taco QUOTE:
"The only way to adjust caster and camber is with new bushings so I went and bought myself some 4 degree adjustable caster camber bushings and got to work. I adjusted the bushings to add 3 degrees of positive caster from stock settings and set it neutral on camber which in effect was -0.25 from stock since the stock alignment had a +0.25 bushing for camber"
END QUOTE
I am very interested in identifying the bushings you found that allow for the +3 degrees. The only ones I am familiar with are the +/- 2 degree Ingalls 594s. Thanks in advance.
END QUOTE
38,777 PostsLatest Activity: May 20, 2026
