Harvard
Feb 27, 2015Explorer
Hank85713 wrote:
I went to a local truck alignment place yesterday to ask about my 2012 E450 problems. I asked if the R&R of the sway bars would do anything to help. I also asked about the changes on the camber as have been reported here and their response to both was to let them look 1st. They did say if not having bow wave push that the sway bars would do little. As to the camber changes they said increased tire wear would be the result. The said to add (already have) rear air assist and try. I run around 55-60 psi in the airbags and it did help. They also told me that they had another winnebago in the shop with 20K on it and it had worn front end parts forget which but I think they said tierod ends. Anyhow haven't gotten the thing out yet to be checked will let ya know. They also said not to worry about getting it aligned with travel weights loaded that the basic weight was fine.
Are you sure you are not mixing up CAMBER and CASTER. It is the CASTER setting where we are recommending to be set in the high end of normal. NOT CAMBER. Caster does not effect tire wear.
38,777 PostsLatest Activity: May 20, 2026
