Georgew48
Jan 09, 2016Explorer
Does not have the auto start but can get it as an add on. Mine has a 2000watt pure sine wave inverter that is just for the residential refegrator. It also has the 70 amp converter with charge wizard built in. Comes with four 12 volt house batteries and one coach battery. The charge wizard will keep them all charged and maintained as long as you are plugged in or running the generator. I assume by auto start you mean the system that will start the generator if you are away from the coach and have a power failure.
