iggyAZ wrote:
SLIDEx
Gas engines get about the same as the diesels so mpg should be a factor. With a smaller Georgetown you should be able to get 8mpg or better on highway.
Just a small correction. Diesels get at least 2-3 mpg better than the same size gas unit. Usually, diesel coaches weigh more but if you were to have a diesel engine in your Georgetown, you would be getting closer to 11 mpg at your weight.
Now, it's the cost of fuel that makes gas and diesel a wash as diesel can be 50 cents more per gallon then regular gas.
MM.
